[gdal-dev] DXF to Postgis using ogr2ogr
Bob Pawley rjpawley at shaw.ca
Tue Dec 27 13:48:33 EST 2011
Something is still not penetrating this thick skull of mine.
When I run
ogr2ogr --config DXF_INLINE_BLOCKS FALSE  --config        DXF_MERGE_BLOCK_GEOMETRIES FALSE  -f "PostgreSQL" PG:"host=localhost user=postgres dbname=db password=pass"  W_Works.dxf -overwrite -skipfailures  -sql "SELECT ST_Translate(ST_Scale(ST_Rotate((ST_Dump(b.wkb_geometry)).geom, e.blockangle / 180 * PI()), e.blockscale[1], e.blockscale[2]), ST_X(e.wkb_geometry), ST_Y(e.wkb_geometry)) AS wkb_geometry, CASE WHEN b.ogr_style IS NOT NULL THEN b.ogr_style ELSE e.ogr_style END AS ogr_style, e.layer, e.linetype, e.subclasses, b.text FROM entities e INNER JOIN blocks b USING (blockname)"
I get error - Undefined function `st_dump`used.
When I run a simplified version
ogr2ogr --config DXF_INLINE_BLOCKS FALSE --config  DXF_MERGE_BLOCK_GEOMETRIES FALSE  -f "PostgreSQL" PG:"host=localhost user=postgres dbname=db password=pass" W_Works.dxf    -overwrite -skipfailures  -sql "SELECT wkb_geometry From entities"
I get error - unrecognized field name wkb_geometry
In the last, when I substitute wkb_geometry for the blocks (name, angle, scale) or text I get no errors.
In all of the commands I`ve run, the block table remains empty.
Bob
Sent: Wednesday, December 21, 2011 1:30 AM
To: Bob Pawley
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] DXF to Postgis using ogr2ogr
On Import you can't use -nln option or you run ogr2ogr to times. One for entities layer and secound for blocks.
ogr2ogr -f postgresql -nln myentities PG:"..." W_Works.dxf entities
ogr2ogr -f postgresql -nln myblocks PG:"..." W_Works.dxf blocks
If you haven't the legacy functions import into your postgis installation you need to prefix with "ST_" Translate, Scale, Rotate and Dump.
On Dienstag 20 Dezember 2011 22:30:20 Bob Pawley wrote:
> When I run
> ogrinfo --config DXF_INLINE_BLOCKS FALSE W_Works.dxf
> it results in this message
> Open of `W_Works.dxf'
> using driver `DXF' successful.
> 1: blocks
> 2: entities
> And I’m using DraftSight as a drawing viewer.All of the information I want
> is on the model, but it still won’t import unless I explode the dxf file
> before saving.
> I did try running your suggested sql command. I got an error “Undefined
> function ‘Dump’ used.
> I also used the sql suggestion as a trigger function on the import table.
> Neither blocks nor entities were recognized.
> Bob
> From: Ralf Suhr
> Sent: Monday, December 19, 2011 8:52 AM
> To: Bob Pawley
> http://www.gdal.org/ogr/drv_dxf.html
> Does ogrinfo print out the "blocks" layer?
> ogrinfo --config DXF_INLINE_BLOCKS FALSE File.dxf
> INFO: Open of `File.dxf'
> 1: blocks
> 2: entities
> To see what can be imported by ogr use a dxfviewer that display only the
> model space. I have tested ogr with dxf version up to AC1018 without
> problems except the paper space.
> Gr
> Ralf
> On Montag 19 Dezember 2011 17:21:58 Bob Pawley wrote:
> > Thanks Ralf
> > So far, I haven’t been able to populate the block columns unless I use a
> > DXF file which has been exploded before saving.
> > In all of my searching, I have not come across your suggestion of
> > dereferencing the block. Can you point me to some documentation?
> > Bob
> > From: Ralf Suhr
> > Sent: Monday, December 19, 2011 12:58 AM
> > To: gdal-dev at lists.osgeo.org
> > Cc: Bob Pawley
> > Hi Bob,
> > the dxf driver writes to tables "entities" and "blocks". You have to
> > dereference the block layer yourself.
> > SELECT Translate( Scale( Rotate((Dump(b.wkb_geometry)).geom, e.blockangle
> > AS
> > ogr_style,
> > e.layer,
> > e.linetype,
> > e.subclasses,
> > b.text
> > FROM entities e
> > INNER JOIN
> > blocks b USING (blockname);
> > Sometimes you have blocks with world coordinates and no connection in
> > entities.
> > SELECT (Dump(b.wkb_geometry)).geom AS wkb_geometry,
> > b.ogr_style,
> > b.layer,
> > b.linetype,
> > b.subclasses,
> > b.text
> > FROM blocks b
> > WHERE blockname NOT IN
> > SELECT DISTINCT blockname
> > FROM entities
> > WHERE blockname IS NOT NULL
> > Some newer DXF Formats can have features in paper space. This is now not
> > supported by ogr2ogr.
> > Gr
> > Ralf
> > On Freitag 16 Dezember 2011 22:14:38 Bob Pawley wrote:
> > > I have imported a dxf file into Postgis using the following command
> > > line
> > > set DXF_INLINE_BLOCKS=FALSE&set DXF_MERGE_BLOCK_GEOMETRIES=FALSE&set
> > > PGCLIENTENCODING=LATIN1&&ogr2ogr -f "PostgreSQL" PG:"host=localhost
> > > user=postgres dbname=dbname password=pass" W_Works.dxf -nln Import_PID
> > > -overwrite –skipfailures
> > > All geometries are intact.
> > > However, the text is part of the Linestring layer and not in the text
> > > column of the Postgresql table.
> > > Is this to be expected?
> > > Is there some way of screening out the text as text and point geometry?
> > > Bob
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111227/061e5850/attachment-0001.html
