[gdal-dev] bit length overflow in deflate compress
Even Rouault even.rouault at mines-paris.org
Thu Dec 29 14:28:41 EST 2011
Le jeudi 29 décembre 2011 20:15:32, Ivan Lucena a écrit :
> Hi there,
> I am getting a lot of messages like that when using deflate compression
> (zlib):
> $ gdal_translate input.tif output.tif -co compress=deflate
> Input file size is 800, 600
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> bit length overflow
> code 4 bits 5->6
> bit length overflow
> code 16 bits 6->7
> bit length overflow
> code 11 bits 6->7
> bit length overflow
> code 5 bits 6->7
> code 11 bits 6->7
> bit length overflow
> code 3 bits 6->7
> bit length overflow
> code 5 bits 5->6
> bit length overflow
> code 5 bits 6->7
> code 12 bits 6->7
> bit length overflow
> code 11 bits 6->7
> bit length overflow
> code 12 bits 6->7
> bit length overflow
> code 16 bits 6->7
> The input and output image has the same checksum at the end, so what is
> going on?
Ivan, I suppose you are using GDAL internal zlib. This error message comes
from frmts/zlib/trees.c, and it appears it is only a debug message that is
output if DEBUG is #define 'd (see zutil.h). On a non-debug build, the message
shouldn't appear.
> The image is RGB, GDAL is compiled for 32bits running in a win64 machine.
> Regards,
> Ivan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
