[gdal-dev] Problem reprojecting DEM lat long to utm
Horsto muhthrael at gmx.de
Thu Feb 3 18:26:15 EST 2011
Hi everybody,
For hours I have been trying to reproject a dem-file to utm zone 40, using
following command:
gdalwarp -t_srs '+proj=utm +zone=40 +datum=WGS84' srtm_47_05.tif dem.tif
It seems that the coordinate system remains in old parameters. When I load
the file in Q-GIS, the map is not located on other correctly projected
UTM-40-maps but far away (as it should be with the Center coordinate
52.5000005,  37.5000001).
Can anybody show me the mistake I am making?
Thanks for helping
Horsto
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-reprojecting-DEM-lat-long-to-utm-tp5990955p5990955.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
