[gdal-dev] gdal_rasterize 1.8.0 options
Even Rouault even.rouault at mines-paris.org
Fri Feb 4 18:06:22 EST 2011
Le vendredi 04 février 2011 20:25:43, Marius Jigmond a écrit :
> Hi Everyone,
> Some of the options (I didn't test all) introduced with version 1.8.0
> seem to behave strangely. Here's what I'm doing:
> 1. gdal_rasterize -burn 0 -i -l mask mask.shp sample.tif
> works fine but I get the following warning:
> Warning : the output raster dataset and the input vector layer do not
> have the same SRS.
> Results might be incorrect (no on-the-fly reprojection of input data).
> even though both inputs use the same projection, EPSG:3844.
Unrelated with GDAL 1.8.0. The issue was that the transformation between OGC
WKT and ESRI WKT didn't handle well the Oblique Stereographic projection.
Fixed in trunk in http://trac.osgeo.org/gdal/changeset/21627
> 2. gdal_rasterize -burn 0 -i -a_srs EPSG:3844 -l mask mask.shp
> sample.tif
> fails with: '-tr xres yes' or '-ts xsize ysize' is required.
> 3. gdal_rasterize -burn 0 -i -a_nodata 0 -l mask mask.shp sample.tif
> >From http://www.gdal.org/gdal_rasterize.html it doesn't seem that -a_srs
> or -a_nodata would require -tr or -ts. Am I doing something wrong?
When those 2 new options are used, they imply creating a new dataset. So they
actually need to be used with -tr or -ts option.
> -marius
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
