[gdal-dev] Re: gdal_rasterize 1.8.0 options
Hermann Peifer peifer at gmx.eu
Sat Feb 5 08:47:17 EST 2011
On 05/02/2011 13:12, Even Rouault wrote:
> I've just had a look, but not being neither Dutch nor a specialist of
> (stereographic) projections, I don't feel competent enough to do any action on
> it. Those tickets plus the reading of
> http://udig.refractions.net/files/docs/api-
> geotools/org/geotools/referencing/operation/projection/Stereographic.html make
> me deeply confused and wondering if r21627 was really appropriate.
Hmm. This page confirms what I mentioned in ticket #2869:
"Double_Stereographic" is simply the ESRI alias of
"Oblique_Stereographic" (EPSG code 9809).
About r21627: I am afraid I do not understand enough about the inner
workings of GDAL/OGR to make a judgement about whether this change was
appropriate or not.
But by the end of the day and from what I remember when looking somewhat
deeper into the issue, about 2 years ago: there is one stereographic
projection (known as "the USGS formula" or "the approach given by
Snyder") which translates into +proj=stere, and there is the other
"Double_Stereographic", aka "Oblique_Stereographic" which is expected to
end up as +proj=sterea.
Hermann
