[gdal-dev] OGR Shapefile SQL with date in where clause
Nicolas Simon nicolas.simon at spw.wallonie.be
Mon Feb 7 10:35:21 EST 2011
Paolo,
I have no error on the command line... and an empty result in the destination file.
I'm using GDAL 1.6.1, could it be the reason ?
Thk
Nicolas
> -----Message d'origine-----
> De : Paolo Corti [mailto:pcorti at gmail.com]
> Envoyé : lundi 7 février 2011 16:26
> À : Nicolas Simon
> Cc : gdal-dev at lists.osgeo.org
> Objet : Re: [gdal-dev] OGR Shapefile SQL with date in where clause
> On Mon, Feb 7, 2011 at 4:08 PM, Nicolas Simon
> <nicolas.simon at spw.wallonie.be> wrote:
> > Hello,
> >         I would like to extract feature from a shapefile
> layer based on a
> > Date field.
> >         But I don't know how to format date value
> >         Here is a defect command
> > ogr2ogr -f "ESRI Shapefile" extrait.shp fulldataset.shp
> -sql "select * from
> > fulldataset where VISTERRAIN = '2010/12/07' "
> >         Help will be welcome.
> >         Thank you
> >         Nicolas Simon
> Hi Nicolas
> I am using gdal 1.8 and it is working for me, look at the output:
> ogrinfo -al poi.shp
> INFO: Open of `poi.shp'
>       using driver `ESRI Shapefile' successful.
> Layer name: poi
> Geometry: Point
> Feature Count: 3
> Extent: (-5106701.348438, -1250725.685421) - (-17541.662933,
> 4118769.067506)
> Layer SRS WKT:
> PROJCS["WGS_1984_UTM_Zone_32N",
>     GEOGCS["GCS_WGS_1984",
>         DATUM["WGS_1984",
>             SPHEROID["WGS_1984",6378137.0,298.257223563]],
>         PRIMEM["Greenwich",0.0],
>         UNIT["Degree",0.0174532925199433]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["False_Easting",500000.0],
>     PARAMETER["False_Northing",0.0],
>     PARAMETER["Central_Meridian",9.0],
>     PARAMETER["Scale_Factor",0.9996],
>     PARAMETER["Latitude_Of_Origin",0.0],
>     UNIT["Meter",1.0]]
> mydate_d: Date (10.0)
> mydate_s: String (50.0)
> OGRFeature(poi):0
>   Id (Integer) = 0
>   mydate_d (Date) = 2010/08/11
>   mydate_s (String) = (null)
>   POINT (-4071618.022572413086891 4118769.067506278399378)
> OGRFeature(poi):1
>   Id (Integer) = 0
>   POINT (-5106701.348437865264714 668491.314621437806636)
> OGRFeature(poi):2
>   Id (Integer) = 0
>   mydate_d (Date) = 2010/11/11
>   POINT (-17541.662932725295832 -1250725.685420754598454)
> ogr2ogr out.shp poi.shp -sql "select * from poi where
> mydate_d = '2010/08/11'"
> ogrinfo -al out.shp
> INFO: Open of `out.shp'
> Layer name: out
> Geometry: Point
> Feature Count: 2
> Extent: (-5106701.348438, 668491.314621) - (-4071618.022572,
> 4118769.067506)
> Layer SRS WKT:
>         DATUM["WGS_1984",
>         UNIT["Degree",0.017453292519943295]],
>     UNIT["Meter",1.0]]
> OGRFeature(out):0
>   Id (Integer) = 0
> OGRFeature(out):1
>   Id (Integer) = 0
> What error do you get?
> best regards
> P
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @paolo_corti
