> Perhaps try setting the environment variable GDAL_DRIVER_PATH to > /usr/lib/gdal17plugins Ok, that finally did the trick. Thanks for your help. $ export GDAL_DRIVER_PATH=/usr/lib/gdal17plugins Is this normally set as part of the install? (e.g. should I report a packaging bug?) -- -matt
