[gdal-dev] Re: PHP bindings
Tamas Szekeres szekerest at gmail.com
Tue Feb 8 15:44:54 EST 2011
Mike,
Actually the PHP bindings are not maintained at all, so any improvements in
this topic would be welcomed. You might also want to regenerate the bindings
with SWIG since the committed version may be outdated. You should also make
sure the corresponding gdal core is available load (proably by setting
LD_LIBRARY_PATH).
Best regards,
Tamas
2011/2/8 Mike Leahy <mgleahy at alumni.uwaterloo.ca>
>  Hi again,
> I recognize this perhaps isn't a popular topic. However, I thought I'd give
> the PHP bingings a try with the latest 1.8.0 release. It's somewhat
> promising to see that enabling the php bindings in the ./configure options
> and compiling will succesfully produce a php_gdal.so library. After finding
> this, I ran make install for gdal, then copied the php_gdal.so to the PHP
> modules folder and configured PHP to load it. Unfortunately, I get the
> following output in the Apache error logs when I attempt to load the module
> in PHP:
> PHP Warning: PHP Startup: Unable to load dynamic library
> '/usr/lib/php5/20090626+lfs/php_gdal.so' -
> /usr/lib/php5/20090626+lfs/php_gdal.so: undefined symbol:
> CPLLoggingErrorHandler in Unknown on line 0
> I'm not really sure where to look next. Could it be a compatibility issue
> with PHP 5.3.3, or maybe for some reason the php module isn't able to access
> the installed gdal libraries?
> Any suggestions would be welcome. I'm testing this in a minimal 64-bit
> Ubuntu 10.11 VM.
> Regards,
> Mike
> On Sunday, February 06, 2011 14:50:34 Mike Leahy wrote:
> > Hello List,
> > Does anyone have an idea if there is any likelihood for a revival of php
> > bindings for GDAL/OGR. I know if these were available, I'd be making use
> > of them...although, I have no experience creating/maintaining SWIG
> > libraries. So I'm curious to know what someone would need to know to get
> > started on this, and how big of a job would it likely be?
> > Regards,
> > Mike
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110208/c1548c0b/attachment.html
