[gdal-dev] Help with import gdal import in python
Wed Feb 9 11:40:38 EST 2011
On 11-02-09 11:23 AM, Giacomo Piva wrote:
> Hi all,
> I'm getting this error when calling gdal_merge.py command.
> Traceback (most recent call last):
> File "/home/meeo/bin/gdal_merge.py", line 31, in ?
> import gdal
> File "/usr/lib/python2.4/gdal.py", line 7, in ?
> import _gdal
> ImportError: No module named _gdal
> I don't know python 'cause I don't know how to solve this problem.
> Any suggestion?
Giacomo,
With all due respect you haven't given much context.   Did you build
and install GDAL and the python bindings yourself?
I imagine the problem is related either to the _gdal.so file not being
found, or it not loading because the underlying libgdal.so.* file not
being found.  Does _gdal.so exist in:
   /usr/lib/python2.4/osgeo
Best regards,
