[gdal-dev] Re: gdapwarp problem
Adam Dershowitz, Ph.D., P.E. adershowitz at exponent.com
Fri Feb 11 17:40:03 EST 2011
On Feb 11, 2011, at 10:20 AM, Adam Dershowitz, Ph.D., P.E. wrote:
> I am having a problem trying to use gdalwarp.  Perhaps I am just missing something, but I figured I would see if someone can help.
> I downloaded some aerial imagery from here:
> http://www.michigan.gov/dnr/0,1607,7-153-10371_14546-30211--,00.html
> I want to import it into a UTM zone 17 project.  So I did the following:
> gdalwarp -t_srs '+proj=utm +zone=17 +datum=WGS84' input.sid output_utm.sid
> gdapwarp responds with an error, but then continues with the conversion:
> ERROR 6: Failed to initialize PROJ.4 with `+proj=omerc +lat_0=0 +lonc=0 +alpha=0 +k=1 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs '.
> lat_0 = 0 or 90 or alpha = 90
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> It does complete, but the area of interest is in the range of UTM (254500,4734000) and the output of gdalwarp is around 663144,240035.
> Any suggestions for what I might be doing wrong?
> If I do gdalinfo on the original file here is what I get:
I googled around some and it looks like this is actually an issue with the Michigan projection in Proj4.
I found this link:
http://www.osgeo.org/pipermail/mapserver-users/2006-July/018292.html
And this seems to give reasonable results, based on the above:
gdalwarp -t_srs '+proj=utm +zone=17 +datum=WGS84' -s_srs '+proj=omerc +lat_0=45.309166667 +lonc=-86.0 +alpha=337.255555556 +k=0.9996 +x_0=499839.8337 +y_0=528600.2398 +ellps=GRS80 +datum=NAD83 +units=m' oakgrove_sw.sid oakgrove_sw_utm.tifg
So, I am not really sure about the source of these numbers, but it does look pretty close.
--Adam
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110211/1edabc2b/attachment.html
