[gdal-dev] Re: gdal-dev Digest, Vol 81, Issue 27
Mike Leahy mgleahy at alumni.uwaterloo.ca
Fri Feb 11 18:05:25 EST 2011
Hi Joris,
You're ahead of me already, as I don't have any real experience with C/C++.
However, I would be interested to see specifically how you're getting the
SpatialReference objects to work...since I'm at least able to compile and load
that particular module.  Do you have a bit of sample code that can demonstrate
this?  As I noted in a previous post to this list, I seem to get zeros
returned by the relevant functions...so either the compiled module I have
isn't working right, or I'm not using it right.  It would be helpful if I
could compare my tests with the way you've done it.
Best regards,
Mike
On Friday, February 11, 2011 12:00:11  Joris van de Sande wrote:
> Date: Fri, 11 Feb 2011 12:50:41 +0100
> From: Joris van de Sande <joris.devplace at gmail.com>
> Subject: [gdal-dev] Reviving the PHP Bindings
> To: gdal-dev at lists.osgeo.org
> Message-ID:
>         <AANLkTin4SjA8uqswvFY9E0ZKV86esfYdgrB=uAaXHrtP at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hello,
> This is a reply to the PHP Bindings thread that has been started by
> Mike Leahy.I have just registered with the list, so I was not able to
> reply to the thread.
> I am also interested in getting the PHP bindings for GDAL up to date.
> Right now we're using the gdal command line utilities a lot from
> within PHP. We're relying on regular expressions to parse the output
> at the moment. So it would make development a lot easier if we could
> use the internal GDAL classes and functions from within PHP.
> A few months ago I have created a little PHP module that converts
> projection strings from wkt to proj format (and vice versa) using the
> SpatialReference class. But it would be great if more functionality
> could be used from inside PHP.
> What can be done to revive the PHP bindings? Are more people interested
> I am a PHP developer with some knowledge of C/C++. My main interest at
> the moment are:
> 1. Using the SpatialReference class from within PHP
> 2. Retrieving map(meta)data like gdalinfo does from within PHP
> Regards,
> Joris van de Sande
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110211/71553f2a/attachment.html
