[gdal-dev] gdal convert shape to raster
Chaitanya kumar CH chaitanya.ch at gmail.com
Sat Feb 12 11:49:36 EST 2011
Rashad,
You did not send me raster you are writing to. If you are creating the
raster with gdal_rasterize, remove the -b options.
On Sat, Feb 12, 2011 at 8:47 PM, Mohammed Rashad <mohammedrashadkm at gmail.com
> wrote:
> gdal_rasterize -b 1 -b 2 -b 3 -burn 255 -burn 0 -burn 0 -l ernakulam
> data/ernakulam.shp gtopo30_shade.tif
> On Sat, Feb 12, 2011 at 8:30 PM, Chaitanya kumar CH <chaitanya.ch@
> gmail.com> wrote:
>> Send me a small shapefile you used along with the command you used on it.
>> On Sat, Feb 12, 2011 at 8:27 PM, Mohammed Rashad <
>> mohammedrashadkm at gmail.com> wrote:
>>> i tried the examples but no output
>>> On Sat, Feb 12, 2011 at 8:26 PM, Chaitanya kumar CH <chaitanya.ch@
>>> gmail.com> wrote:
>>>> Rashad,
>>>> Look at the examples in it's doc page.
>>>> http://www.gdal.org/gdal_rasterize.html
>>>> On Sat, Feb 12, 2011 at 8:22 PM, Mohammed Rashad <
>>>>> How to convert shapefile to raster using gdal or gdal_rasterize
>>>>> Thanks && Regards
>>>>> Rashad
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> /tʃaɪθənjə/ /kʊmɑr/
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
>>> Thanks && Regards
>>> Rashad
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
> Thanks && Regards
> Rashad
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110212/e9782063/attachment-0001.html
