[gdal-dev] nmake.local on windows builds
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Feb 15 13:55:57 EST 2011
On 11-02-15 2:47 PM, Frank Warmerdam wrote:
> Well, either way will work. But *my* recommendation is creating an
> nmake.local with GDAL trunk and beyond. This is better than editing
> nmake.opt directly particularly in the case where you later want to
> do svn update's and rebuilds. If you hand edit the nmake.opt there is
> a significant risk of needless merge conflicts.
I like your recommendation, and I will switch to this nmake.local
method.  Thanks for the tip.
-jeff
