[gdal-dev] gdalwarp reprojection problem
heng.feng heng.feng at aircominternational.com
Wed Feb 16 02:28:12 EST 2011
Hi there,
When I tried to use GDALWARP to do the re-projeciton on some large GeoTiff
data, the output pictures seemed to contain the gaps, which appeared to be a
few horizontal lines when zooming out. The command I was using is something
like this:
gdalwarp --config GDAL_CACHEMAX 250 -wm 250 -co TILED=YES -co COMPRESS=LZW
-s_srs "+proj=tmerc +lat_0=0 +lon_0=12 +k=1.000000 +x_0=4500000 +y_0=0
+ellps=bessel +datum=potsdam +nadgrids=c:\fh\BETA2007.gsb,null +units=m
+wktext" -t_srs "+proj=utm +datum=WGS84 +zone=32"
"Z:\JBRoadMaps100\100\100.tif" "Z:\JBRoadMaps100\100\100_converted.tif"
This problem seems to be only happening to the large data as I have used the
same GDALWARP command on the smaller data and everything was working fine
(with no gap at all). Also the bigger is the data, more gaps/lines the
output picture will have. I have also tried to increase/decrease
GDAL_CACHEMAX and –wm values and it does not make any difference (the same
amount of gaps still exists in the same output data).  I suspect this
problem is caused by the option “-co TILED=YES”, but once I removed this
option, the re-projection process was hanging. Moving the map data onto the
local disk does not ease this problem either.
Can anyone here give me some help regarding this problem?
Thanks,
Heng
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdalwarp-reprojection-problem-tp6030749p6030749.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
