[gdal-dev] Mosaicking Orthos
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Feb 16 12:39:38 EST 2011
Zoltan,
Have you tried the nearblack GDAL utility on the original 176 images?
http://www.gdal.org/nearblack.html
On Wed, Feb 16, 2011 at 5:25 PM, Zoltan Szecsei <zoltans at geograph.co.za>wrote:
> On 2011-02-16 12:20, Zoltan Szecsei wrote:
>> Hi All,
>> I've built a vrt with 176 images.
>> I now need to mosaic this whole area into roughly 5 x 5 ortho images.
>> How can I force the white edges into background of the overlapping orthos?
>> I'm a little cautious of simply (finding a way to) making "white"
>> transparent as it is only the white on the edges that need to be
>> backgrounded.
> Hi again,
> Since the above post, I have tried different ways to set nodata, but to no
> avail - I still get the white edges:
> (see jpeg sent with my original post)
> gdalbuildvrt -addalpha -hidenodata -input_file_list files
> 177_untiled_orthos_nodata.vrt
> gdalbuildvrt -srcnodata "0 0 0"  -addalpha -hidenodata -input_file_list
> files 177_untiled_orthos_blk.vrt
> gdalbuildvrt -srcnodata "255 255 255"  -addalpha -hidenodata
> -input_file_list files 177_untiled_orthos_white.vrt
> How should I be masking out the nodata (or even white pixels) so that when
> I mosaic a bunch of tiffs together, I dont get the white stripes in the
> resulting image?
> Using GDAL 1.7.3, released 2010/11/10 on Ubuntu 10.04
> Viewing with Quantum GIS - 1.6.0-Trunk on Ubuntu 10.04 (same box).
> ...but running the whole lot in xterms with Xming & putty from my WinVista
> box.
> Regards,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> P.O. Box 7, Muizenberg 7950, South Africa.
> 65 Main Road, Muizenberg 7945
> Western Cape, South Africa.
> 34° 6'16.35"S 18°28'5.62"E
> Tel: +27-21-7884897  Mobile: +27-83-6004028
> Fax: +27-86-6115323     www.geograph.co.za
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 10.0.1204 / Virus Database: 1435/3446 - Release Date: 02/15/11
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110216/0355b08f/attachment.html
