[gdal-dev] gdal install error version 1.5.0
Mohammed Rashad mohammedrashadkm at gmail.com
Thu Feb 17 08:41:15 EST 2011
Install error; console log
bin/sh /home/rashadkm/gdal-1.5.0/libtool --mode=compile --tag=CXX
arm-linux-androideabi-g++ -g -O2  -Wall  -I/home/rashadkm/gdal-1.5.0/port
-I/home/rashadkm/gdal-1.5.0/gcore -I/home/rashadkm/gdal-1.5.0/alg
-I/home/rashadkm/gdal-1.5.0/ogr -I/home/rashadkm/gdal-1.5.0/ogr/ogrsf_frmts
-c -o ../o/ilwisdataset.o ilwisdataset.cpp
libtool: compile:  arm-linux-androideabi-g++ -g -O2 -Wall
-I/home/rashadkm/gdal-1.5.0/port -I/home/rashadkm/gdal-1.5.0/gcore
-I/home/rashadkm/gdal-1.5.0/alg -I/home/rashadkm/gdal-1.5.0/ogr
-I/home/rashadkm/gdal-1.5.0/ogr/ogrsf_frmts -c ilwisdataset.cpp  -fPIC -DPIC
-o ../o/.libs/ilwisdataset.o
In file included from /home/rashadkm/gdal-1.5.0/gcore/gdal_priv.h:54,
                 from /home/rashadkm/gdal-1.5.0/gcore/gdal_pam.h:33,
                 from ilwisdataset.h:34,
                 from ilwisdataset.cpp:30:
/home/rashadkm/gdal-1.5.0/port/cpl_string.h:173: note: the mangling of
'va_list' has changed in GCC 4.4
ilwisdataset.cpp: In function 'CPLErr GetStoreType(std::string,
ilwisStoreType&)':
ilwisdataset.cpp:409: error: no matching function for call to
'transform(__gnu_cxx::__normal_iterator<char*, std::basic_string<char,
std::char_traits<char>, std::allocator<char> > >,
std::char_traits<char>, std::allocator<char> > >, <unresolved overloaded
function type>)'
ilwisdataset.cpp: In member function 'void
ILWISDataset::CollectTransformCoef(std::string&)':
ilwisdataset.cpp:485: error: no matching function for call to
function type>)'
ilwisdataset.cpp: In static member function 'static GDALDataset*
ILWISDataset::Open(GDALOpenInfo*)':
ilwisdataset.cpp:791: error: no matching function for call to
function type>)'
ilwisdataset.cpp: In member function 'CPLErr
ILWISRasterBand::GetILWISInfo(std::string)':
ilwisdataset.cpp:1321: error: no matching function for call to
function type>)'
ilwisdataset.cpp:1373: error: no matching function for call to
function type>)'
make[2]: *** [../o/ilwisdataset.o] Error 1
make[2]: Leaving directory `/home/rashadkm/gdal-1.5.0/frmts/ilwis'
make[1]: *** [ilwis-install-obj] Error 2
make[1]: Leaving directory `/home/rashadkm/gdal-1.5.0/frmts'
make: *** [frmts-target] Error 2
Thanks && Regards
Rashad
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110217/f4a6090a/attachment.html
