[gdal-dev] Re: gdal android
Thu Feb 17 09:58:17 EST 2011
On 11-02-17 06:00 AM, Mohammed Rashad wrote:
> here is my new error log
> cpl_strtod.cpp: In function 'void CPLReplacePointByLocalePoint(char*, char)':
> cpl_strtod.cpp:200: error: 'struct lconv' has no member named 'decimal_point'
> cpl_strtod.cpp:201: error: 'struct lconv' has no member named 'decimal_point'
> cpl_strtod.cpp:204: error: 'struct lconv' has no member named 'decimal_point'
> make[1]: *** [cpl_strtod.lo] Error 1
> make[1]: Leaving directory `/home/rashadkm/gdal-1.8.0/port'
> make: *** [port-target] Error 2
> Which gdal version to use for Android
Rashad,
My copy of cpl_strtod.cpp (trunk) has an ifdef in that function for the
__ANDROID__ case.  Do you?  If yes, I wonder why it isn't getting activated.
Perhaps you should review the fairly new android notes at:
   http://trac.osgeo.org/gdal/wiki/BuildingForAndroid
Best regards,
