[gdal-dev] Segmentation fault using gdal_translate in 1.8.0
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Feb 18 06:55:32 EST 2011
Derrick,
I was able to run gdalinfo and gdal_translate on your sample dataset without
any error.
Can you provide some more details like your platform and the settings you
used to compile GDAL?
On Fri, Feb 18, 2011 at 9:57 AM, <Derrick.Wong at csiro.au> wrote:
> Hi Kyle,
> Thanks for the reply.
> Gdalinfo on 1.8.0 gives me the same “Segmentation fault” error.
> Attached is the dump using 1.7.3
> I have included a sample file and you can download it here:
> ftp://ftp.csiro.au/DerrickWong/sample/sample.nc
> *Derrick Wong** *
> Software Engineer *|* Spatial Information Services Stack (SISS) Project *|
> *CSIRO
> Phone: +61 8 6436 8945
> derrick.wong at csiro.au *|* www.csiro.au
> Address: Spatial Information Services Stack (SISS), 26 Dick Perry Avenue,
> Kensington WA 6151, Australia
> *PLEASE NOTE**
> *The information contained in this email may be confidential or
> privileged. Any unauthorised use or disclosure is prohibited. If you have
> received this email in error, please delete it immediately and notify the
> sender by return email. Thank you. To the extent permitted by law, CSIRO
> does not represent, warrant and/or guarantee that the integrity of this
> communication has been maintained or that the communication is free of
> errors, virus, interception or interference.
> *Please consider the environment before printing this email.*
> *From:* Kyle Shannon [mailto:ksshannon at gmail.com]
> *Sent:* Friday, 18 February 2011 11:32 AM
> *To:* Wong, Derrick (CESRE, Kensington)
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Segmentation fault using gdal_translate in 1.8.0
> Derrick,
> Can you file a ticket and attach a sample data set?  Do you have any other
> details?  A gdalinfo of the netcdf file and another of one of the variables
> would be great.  Thanks.
> kss
> Kyle Shannon
> Physical Science Technician
> RMRS Fire Sciences Lab
> Fire, Fuels & Smoke - RWU 4405
> 5775 Highway 10 W.
> Missoula, MT 59808
> (406)829-6954
> kshannon at fs.fed.us
> On Thu, Feb 17, 2011 at 19:54, <Derrick.Wong at csiro.au> wrote:
> Hi all,
> I have updated to use GDAL 1.8 and I am having problems using
> gdal_translate to convert netCDF files to Geotiff or ERS. I am getting
> “Segmentation fault” errors only occurring in 1.8.0. I was using 1.7.3
> previously.
> Could someone kindly advise?
> Thank you for your time.
> *Derrick Wong *
> *CSIRO
> *PLEASE NOTE**
> gdal-dev mailing list
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110218/958f7d6d/attachment-0001.html
