[gdal-dev] Re: GCP list projection
Fri Feb 18 10:34:00 EST 2011
On 11-02-18 03:39 AM, Vadim Shlyakhov wrote:
> So, if you have GCP SRS, you don't need SRS set at the dataset level, do you?
Vadim,
Correct.
> BTW I've noticed if a dataset doesn't have a geotransform, then
> ds.GetGeoTransform() returns (0.0, 1.0, 0.0, 0.0, 0.0, 1.0). Is that a feature
> or a bug?
As mentioned, this the fallback value when there isn't one.  But the method
should return CE_Failure on failure so you can distinguish whether the
unity transform is "real" or just a filler value.
So I consider it a feature.
Best regards,
