[gdal-dev] Segmentation fault using gdal_translate in 1.8.0
Chaitanya kumar CH chaitanya.ch at gmail.com
Sun Feb 20 23:25:11 EST 2011
Derrick,
I tested your sample data on ubuntu with gdal trunk and 1.8 versions.
Check if you are linking to the right gdal library. Just run the command
"gdalinfo --version".
Since the error is coming up only on your system, you have to help me
perform the testing.
Build with the "--enable-debug" configure option and run the program after
setting the environment variable "CPL_DEBUG" to YES. If that doesn't show
any info before segfaulting, run it under the gdb debugger.
On Mon, Feb 21, 2011 at 9:28 AM, <Derrick.Wong at csiro.au> wrote:
> Hi Chaitanya
> I have downloaded and unpacked the tar.gz and compiled it in on a standard
> Debian box.
> Please find attached the config log for the installation.
> I have downloaded a precompiled windows executable (1.8.0) for comparison,
> and I am not having any issues with it though.
> Am I missing an include or something during my build/compile process?
> Please assist.
> Thanks.
> *Derrick Wong** *
> Software Engineer *|* Spatial Information Services Stack (SISS) Project *|
> *CSIRO
> Phone: +61 8 6436 8945
> derrick.wong at csiro.au *|* www.csiro.au
> Address: Spatial Information Services Stack (SISS), 26 Dick Perry Avenue,
> Kensington WA 6151, Australia
> *PLEASE NOTE**
> *The information contained in this email may be confidential or
> privileged. Any unauthorised use or disclosure is prohibited. If you have
> received this email in error, please delete it immediately and notify the
> sender by return email. Thank you. To the extent permitted by law, CSIRO
> does not represent, warrant and/or guarantee that the integrity of this
> communication has been maintained or that the communication is free of
> errors, virus, interception or interference.
> *Please consider the environment before printing this email.*
> *From:* Chaitanya kumar CH [mailto:chaitanya.ch at gmail.com]
> *Sent:* Friday, 18 February 2011 7:56 PM
> *To:* Wong, Derrick (CESRE, Kensington)
> *Cc:* ksshannon at gmail.com; gdal-dev at lists.osgeo.org; Fraser, Ryan (CESRE,
> Kensington)
> *Subject:* Re: [gdal-dev] Segmentation fault using gdal_translate in 1.8.0
> Derrick,
> I was able to run gdalinfo and gdal_translate on your sample dataset
> without any error.
> Can you provide some more details like your platform and the settings you
> used to compile GDAL?
> On Fri, Feb 18, 2011 at 9:57 AM, <Derrick.Wong at csiro.au> wrote:
> Hi Kyle,
> Thanks for the reply.
> Gdalinfo on 1.8.0 gives me the same “Segmentation fault” error.
> Attached is the dump using 1.7.3
> I have included a sample file and you can download it here:
> ftp://ftp.csiro.au/DerrickWong/sample/sample.nc
> *Derrick Wong *
> *CSIRO
> *PLEASE NOTE**
> *From:* Kyle Shannon [mailto:ksshannon at gmail.com]
> *Sent:* Friday, 18 February 2011 11:32 AM
> *Cc:* gdal-dev at lists.osgeo.org
> Derrick,
> Can you file a ticket and attach a sample data set?  Do you have any other
> details?  A gdalinfo of the netcdf file and another of one of the variables
> would be great.  Thanks.
> kss
> Kyle Shannon
> Physical Science Technician
> RMRS Fire Sciences Lab
> Fire, Fuels & Smoke - RWU 4405
> 5775 Highway 10 W.
> Missoula, MT 59808
> (406)829-6954
> kshannon at fs.fed.us
> On Thu, Feb 17, 2011 at 19:54, <Derrick.Wong at csiro.au> wrote:
> Hi all,
> I have updated to use GDAL 1.8 and I am having problems using
> gdal_translate to convert netCDF files to Geotiff or ERS. I am getting
> “Segmentation fault” errors only occurring in 1.8.0. I was using 1.7.3
> previously.
> Could someone kindly advise?
> Thank you for your time.
> *Derrick Wong *
> *CSIRO
> *PLEASE NOTE**
> gdal-dev mailing list
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110221/723bab27/attachment-0001.html
