[gdal-dev] Coulour balancing and feathering, in a VRT
Marius Jigmond mariusjigmond at hotmail.com
Mon Feb 21 08:33:44 EST 2011
With gdal_translate you can do per band re-scaling. I've used it on
Landsat, it's not magic but it works pretty well. You can group your
images, find the right formula for each group and you can quickly verify
the results with a VRT.
-marius
On Mon, 2011-02-21 at 10:39 +0200, Zoltan Szecsei wrote:
> Hi,
> I've been googling around a bit, but no luck yet.
> Now that I have my fancy vrt with a 170 orthos in it, is there a
> (opensource) product I can colour balance and feather with, before I cut
> out the required orthophoto regions?
> Thanks in advance,
> Zoltan
