[gdal-dev] Transform point from UTM to Lat/Long
Jorge Arévalo jorge.arevalo at deimos-space.com
Mon Feb 21 14:18:22 EST 2011
On Mon, Feb 21, 2011 at 7:01 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On 11-02-21 12:43 PM, Jorge Martin wrote:
>> Hello,
>>         I have a big doubt about transforming one point from UTM to
>> Lat/long.
>> I have to make the resampling of a Lat/long image. The target image is UTM
>> with
>> 2.5 resolution. To create the target image I use GDAL, so I have to set
>> the UTM
>> zone, so I set this zone to the zone corresponding to the top left corner
>> of
>> the source image (Lat/long).
>>       When I am reading the all the points of the target (UTM) image and
>> finding the corresponding lat/long coordinates into the source image. I
>> have to
>> transform these points from UTM to Lat/Long. I case the source image
>> covers
>> more than one UTM zone, the transformation between this two coordinate
>> system
>> is not the right.Because the Lat/long of the initial image may corresponds
>>  to
>> a UTM zone different than the one I have fixed for the grid.
>> Is there any way to make this transformation taking into account this
>> problem?
> Jorge,
> I'm not positive I follow your problem, but in the situation of resampling
> an image into a UTM projection when the image overlaps two zones you can
> just pick one with the greatest overlap and use that.
> There is nothing that says you can't reproject to a given utm zone even
> outside it's zone bounds.  But keep in mind that the further you get
> from the central meridian of a zone, the greater the distortion and error
> in how the equations are evaluated.  So you don't want to be using a
> UTM zone several zones away from the image.
> As a rule of thumb, I'd suggest using the center of the image to decide
> on a utm zone.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Hi Jorge,
As Frank said, I'd use the center of the image to decide UTM zone. I
have experience with images covering Spain area (UTM zone 28 for
Canary Island, and 29-31 for Spain). I've obtained positive results
using zone 30 for all Spain except Canary Island.
Best regards,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
