[gdal-dev] Re: [Qgis-developer] Issue saving shapefiles with REAL15 values
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Feb 22 11:39:48 EST 2011
Anita,
Is it possible to send a small sample data to my email for testing? Doesn't
matter if the ID field values are wrong.
On Tue, Feb 22, 2011 at 9:21 PM, Anita Graser <anitagraser at gmx.at> wrote:
> Hi,
> I used the following ogr2ogr command:
> ogr2ogr -sql "select * from nw where NAME = 'Am Johannesberg'" new.shp
> nw.shp
> The resulting shp contains correct geometries, but the values in ID,N,15,0
> fields are broken.
> I guess that shows that it's a GDAL/OGR problem.
> Thanks, best wishes,
> Anita
> Am 22.02.2011, 16:33 Uhr, schrieb Chaitanya kumar CH <chaitanya.ch@
> gmail.com>:
>  Anita,
>> First, let us isolate the source of this error. QGIS or GDAL/OGR.
>> Use ogr2ogr to clip the part you did with QGIS. See the extents of the
>> clipped shapefile using ogrinfo and use it with the ogr2ogr utility.
>> http://www.gdal.org/ogr2ogr.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110222/a0546799/attachment.html
