[gdal-dev] How to use GDAL C++ dynamically?
Even Rouault
even.rouault at mines-paris.org
Tue Feb 22 17:43:43 EST 2011
Le mardi 22 février 2011 23:14:50, Mikhail Tchernychev a écrit :
> Hello List,
> I wonder if someone could point me into the right direction. I would
> like to use
> GDAL as loaded DLL at run time, with LoadLibray() call under windows
> and corresponding
> calls under Linux. I see that most of the functions are virtual, so it
> seems it is made
> with this in mind. I am trying to compile simple program:
I think you are going to inflict you a lot of pain with LoadLibrary() and C++
API at the same time !
If you really need to dynamicly load gdal, use the GDAL C API instead...
> #include "stdafx.h"
> #include <windows.h>
> #define CPL_DLL
> #include "ogrsf_frmts.h"
> typedef void (* pOGRRegisterAll)();
> typedef OGRSFDriverRegistrar * (*pGetRegistar)();
> int _tmain(int argc, _TCHAR* argv[])
> const char *pszDriverName = "ESRI Shapefile";
> HMODULE hDll = LoadLibrary("gdal18.dll");
> if(!hDll) {
> fprintf(stderr,"Cannot load library\n");
> exit(0);
> pOGRRegisterAll pRegFunc =
> (pOGRRegisterAll)GetProcAddress(hDll,"OGRRegisterAll");
> (*pRegFunc)();
> OGRSFDriver *poDriver;
> OGRSFDriverRegistrar * poRegistrar;
> pGetRegistar pRegistrarFunc =
> (pGetRegistar)GetProcAddress(hDll,"?GetRegistrar at OGRSFDriverRegistrar@@SAPA
> V1 at XZ");
> if(pRegistrarFunc == NULL )
> printf( "Cannot get registrar\n");
> exit( 1 );
> poRegistrar = (*pRegistrarFunc)();
> if( poRegistrar == NULL )
> printf( "Cannot get poRegistrar\n");
> exit( 1 );
> // link error here:
> poDriver = poRegistrar->GetDriverByName(pszDriverName);
> if( poDriver == NULL )
> printf( "%s driver not available.\n", pszDriverName );
> exit( 1 );
> return 0;
> This is just part of the GDAL API tutorial.
> I see two problems here:
> 1. I have to use C++ mangled names, which is not very nice. Is there
> .DEF file for GDAL
> with meaningful names?
> 2. I got a link error, which apparently clear why, because
> GetDriverByName() is not virtual.
> Now then could I create new files if GDAL is loaded dynamically?
> I am using latest GDAL source with VC++ 2010
> I tried to search mail list but did not seem find anything.
> Thank you very much,
> Mikhail
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
