[gdal-dev] How to use GDAL C++ dynamically?
Wed Feb 23 14:12:49 EST 2011
On 11-02-22 05:52 PM, Mikhail Tchernychev wrote:
> This is what I normally do, however it's not much less pain, even it's simple.
> I typically write a wrapper to execute all GetProcAdress() functions at once
> and store
> pointers in the class.
> Taking into number of GDAL functions, its' would be very challenging.
> Mikhail
> On 2/22/2011 2:43 PM, Even Rouault wrote:
>> Le mardi 22 février 2011 23:14:50, Mikhail Tchernychev a écrit :
>>> Hello List,
>>> I wonder if someone could point me into the right direction. I would
>>> like to use
>>> GDAL as loaded DLL at run time, with LoadLibray() call under windows
>>> and corresponding
>>> calls under Linux. I see that most of the functions are virtual, so it
>>> seems it is made
>>> with this in mind. I am trying to compile simple program:
>> I think you are going to inflict you a lot of pain with LoadLibrary() and C++
>> API at the same time !
>> If you really need to dynamicly load gdal, use the GDAL C API instead...
Folks,
I will note that at one time I maintained a "bridge" mechanism which
basically did this.  It dynamically loaded the C API at runtime.  I
stopped maintaining it several years ago but you can still find it in
old code branches.
ie.
http://svn.osgeo.org/gdal/tags/gdal_1_2_0/bridge/
If someone felt it was really useful, that might be a good place to
start.
Best regards,
