[gdal-dev] Re: PHP bindings
Mike Leahy mgleahy at alumni.uwaterloo.ca
Thu Feb 24 22:26:28 EST 2011
Hello all,
To keep this topic somewhat alive, I might note that I can identify that
php_osr.so works partially in some ways, but not how I would expect
compared with the same bindings in other languages.
I also found that at least one typemap was needed in typemaps_php.i, which I
determined by looking at the Python typemaps:
/* Almost same as %typemap(out) char **options */
/* but we CSLDestroy the char** pointer at the end */
%typemap(out) char **CSL
  /* %typemap(out) char ** -> ( string ) */
  char **stringarray = $1;
  if ( stringarray == NULL ) {
  else {
    int len = CSLCount( stringarray );
    for ( int i = 0; i < len; ++i, ++stringarray ) {
      add_next_index_string( $result, *stringarray, 1 );
This seems to have removed the warnings about that being missing when I
compile the osr library (I'm continuing to focus just on this library for
In terms of actually using php_osr.so, I can successfully import a proj4
string, and export that to WKT using the '__str__' method:
$sr = new_SpatialReference();
echo SpatialReference___str__($sr);
This suggests to me that the underlying objects work as expected.  However, I
would expect that the last line would be equivalent to using
"SpatialReference_ExportToWkt($sr);", but that isn't the case.  When using
that function, I still get zero, which I think stems from the fact that the
data type for the ExportToWkt (and similar functions) in osr.i is of the type
'OGRErr', and this is what is getting returned in PHP instead of the desired
wkt output.
My guess is that there's a difference in how swig is interpreting these
functions when compiling for PHP versus the other languages.  In osr.i, I
added an extra declaration that mimics how the __str__ function works, but
returns proj4 strings.  It looks like this:
%newobject ExportToProj4Test;
  char *ExportToProj4Test() {
    char *buf = 0;
    OSRExportToProj4( self, &buf );
    return buf;
After compiling that, the following code will successfully return a Proj4
echo SpatialReference_ExportToProj4Test($sr);
So...with this in mind, does this suggest that PHP will essentially need an
entirely rewritten list of functions that substitute those that are currently
there now?  I would hope that there's a more efficient/effective way to go about
this, and that I'm just looking at this with my relatively novice perspective.
Best regards,
> Hi Even,
> It looks like adding '-L../../.libs -lgdal' did the trick to ensure
> that the libraries are linked.  E.g.,:
> swig -Wall -I../include -I../include/php -I../include/php/docs \
>    -I/scratch2/gdal/gdal-1.8.0 -c++ -php -o osr_wrap.cpp
>    ../include/osr.i
> g++ -L../../.libs -lgdal -I../../port -I../../gcore -I../../alg \
>    -I../../ogr `php-config --includes` -fpic -c osr_wrap.cpp
> gcc -L../../.libs -lgdal -shared osr_wrap.o -o php_osr.so
> After doing that, ldd shows a respectable number of linked libraries,
> inlcuding libgdal.  I can load php_osr.so without trouble, same as
> before. But php_gdal.so module now reports several conflicts when it is
> loaded (e.g., duplicate functions named 'rmdir', 'mkdir', 'unlink',
> etc...), so there's a bit more to fix up in that area.
> However, I'm sticking with php_osr.so as a simpler test case to start
> off. As an example, I would expect the PHP code below should create a
> spatial reference object for the wgs84 long/lat referenc system based
> on the epsg number 4326, and export the equivalent WKT text, but I'm
> still getting a zero integer returned:
> php code:
> var_dump($sr);
> var_dump(SpatialReference_ImportFromProj4($sr,'+init=epsg:3587'));
> var_dump(SpatialReference_ExportToWkt($sr));
> outputs:
> "resource(3) of type (_p_OSRSpatialReferenceShadow) int(0) int(0)"
> In python, I can do the following:
> srs = osgeo.osr.SpatialReference()
> srs.ImportFromProj4('+init=epsg:3587')
> print srs.ExportToWkt()
> And I get the following output:
> "GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137,2
> 98 .2
> 57223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]"
> So maybe I just don't know how to interact with the spatial reference
> object within the PHP environment.  Any further suggestions here?
> Regards,
> Mike
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110224/fc90cb13/attachment-0001.html
