[gdal-dev] ogr-to-osm error message
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Fri Feb 25 19:35:30 EST 2011
This looks like a problem in ogr-to-osm, not related to
GDAL/OGR. These segment/node IDs appear to be created internal
to the script and are not related to GDAL/OGR. I would recommend
going to an OpenStreetMap list of some sort to ask this
particular question.
-- Chris
On Feb 26, 2011, at 12:37 AM, ext PJ Houser wrote:
> Hi all,
> We're having this problem when we run ogr-to-osm.py. (from http://svn.openstreetmap.org/applications/utils/import/ogr2osm/) I don't know much about python, so the problem could be obvious. Any help would be appreciated. Thank you.
> G:\PUBLIC\OpenStreetMap\tools\
> ogr-to-osm>.\run.bat -e 4326 G:\PUBLIC\OpenStreetM
> ap\data\shp\trails.shp
> G:\PUBLIC\OpenStreetMap\tools\ogr-to-osm>G:\PUBLIC\OpenStreetMap\tools\usr\Pytho
> n26\python.exe G:\PUBLIC\OpenStreetMap\tools\ogr-to-osm\ogr2osm.py -e 4326 G:\PU
> BLIC\OpenStreetMap\data\shp\trails.shp
> G:\PUBLIC\OpenStreetMap\tools\usr\Python26\lib\site-packages\osgeo\gdal.py:81: D
> eprecationWarning: ogr.py was placed in a namespace, it is now available as osge
> o.ogr
>   DeprecationWarning)
> ([('-e', '4326')], ['G:\\PUBLIC\\OpenStreetMap\\data\\shp\\trails.shp'])
> Preparing to convert file G:\PUBLIC\OpenStreetMap\data\shp\trails.shp (extension
>  is shp) into G:\PUBLIC\OpenStreetMap\data\shp\trails.osm
> Will assume that source data is in EPSG:4326
> Parsing features
> ['OBJECTID', 'TRAILID', 'TRAILNAME', 'SYSTEMNAME', 'SYSTEMTYPE', 'CITYMUNI', 'CO
> UNTY', 'STATE', 'STATUS', 'LENGTH', 'TRLSURFACE', 'WIDTH', 'ACCESSIBLE', 'MOTORI
> ZED', 'HIKE', 'ROADBIKE', 'MTNBIKE', 'EQUESTRIAN', 'WCRAFT_MTR', 'WCRAFT_NON', '
> PORTAGE', 'AGENCYNAME', 'AGENCYTYPE', 'Shape_Leng']
> Got layer field definitions
> Nodes: 189758
> Way segments: 189888
> Lines: 10287
> Areas: 0
> Joining segments
> Simplifying line segments
> Traceback (most recent call last):
>   File "G:\PUBLIC\OpenStreetMap\tools\ogr-to-osm\ogr2osm.py", line 594, in <modu
> le>
>     for nodeID in segmentNodes[segmentID]:
> KeyError: -195887
> PJ Houser
> Trimet, GIS
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
