[gdal-dev] Unrecognized Geopdf files using GDAL 1.8
Even Rouault even.rouault at mines-paris.org
Sun Feb 27 18:42:34 EST 2011
Le lundi 28 février 2011 00:26:43, N. Farah a écrit :
> Hi,
> Using gdalinfo (http://vbkto.dyndns.org:1280/sdk/) on few geopdf files did
> not recognized the files as supported.Other files were opened and
> recognized ok. Here are 3 files that were unrecognized:
> http://www.agc.army.mil/GeoPDFgallery/3D/Fargo.jpg
--> this is a JPEG file ...
You probably meant http://www.agc.army.mil/GeoPDFgallery/3D/Fargo.pdf which is
recognized as a *non* spatial PDF on Linux with Poppler 0.16.0. A dump of the
PDF content shows that there are indeed no spatial info in that PDF that
follow the OGC best practice encoding or Adobe supplement to ISO 32000. And
the name of the file suggests that this is a 3D GeoPDF, which is a specification
not handled by the driver.
> http://www.agc.army.mil/GeoPDFgallery/3D/Fargo_May09_geo.jpg
Same as above
> http://acrobatusers.com/sites/default/files/gallery_pictures/GEOEYE-
INAUGURATION.pdf
--> recognized as a geospatial PDF on Linux with Poppler 0.16.0
Driver: PDF/Geospatial PDF
Files: GEOEYE-INAUGURATION.pdf
Size is 1350, 619
Coordinate System is:
PROJCS["WGS 84 / UTM zone 18N",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4326"]],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-75],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    AUTHORITY["EPSG","32618"],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH]]
GeoTransform =
  322005.63038904, 2.8993752, -0.04217184
  4307533.17691748, -0.13576416, -2.77423392
Metadata:
  NEATLINE=POLYGON ((322005.69019039417617
4307537.110892030410469,325915.627076361211948
4307346.153255709446967,325893.724369931151159
4305634.64386628754437,321983.72777434962336
4305821.667495521716774,322005.630388610996306
4307533.176889259368181,322005.69019039417617 4307537.110892030410469))
Corner Coordinates:
Upper Left  (  322005.630, 4307533.177) ( 77d 3' 9.14"W, 38d53'55.17"N)
Lower Left  (  321979.526, 4305815.926) ( 77d 3' 8.62"W, 38d52'59.48"N)
Upper Right (  325919.787, 4307349.895) ( 77d 0'26.58"W, 38d53'52.05"N)
Lower Right (  325893.683, 4305632.645) ( 77d 0'26.09"W, 38d52'56.36"N)
Center      (  323949.656, 4306582.911) ( 77d 1'47.61"W, 38d53'25.77"N)
>  Thanks
> Noureddine Farah
