[gdal-dev] Deleting fields OGR
Chaitanya kumar CH chaitanya.ch at gmail.com
Sun Jan 2 00:29:05 EST 2011
Håvard,
Currently there is no option for this in ogr2ogr but this looks like a
usable feature. You can file a ticket at
http://trac.osgeo.org/gdal/newticket for this enhancement.
2011/1/2 Håvard Wahl Kongsgård <haavard.kongsgaard at gmail.com>
> With ogr2ogr is it also possible to deselect("reverse selecting") fields?
>> 2011/1/1 Chaitanya kumar CH <chaitanya.ch at gmail.com>
>> Håvard,
>>> You can create a copy of the dataset while skipping the field. For
>>> shapefiles you won't have to mention the .shp file. Opening just the .dbf
>>> file will be enough.
>>> Similar thing can be done using ogr2ogr by specifying the -select option
>>> without the specified field's name. http://www.gdal.org/ogr2ogr.html
>>> 2011/1/1 Håvard Wahl Kongsgård <haavard.kongsgaard at gmail.com>
>>>>  OK; what it the best alternative method in Python etc. to delete
>>>> shapefile fields? Using the shapefile functions in R (via python is one
>>>> alternative).
>>>> 2011/1/1 Even Rouault <even.rouault at mines-paris.org>
>>>> Le samedi 01 janvier 2011 19:08:23, Håvard Wahl Kongsgård a écrit :
>>>>> > Hi, in gdal/ogr is there a function to delete fields(like
>>>>> CreateField())?
>>>>> Not yet, but this has been discussed in
>>>>> http://trac.osgeo.org/gdal/ticket/2671
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Best regards,
>>> Chaitanya kumar CH.
>>> /tʃaɪθənjə/ /kʊmɑr/
>>> +91-9494447584
>>> 17.2416N 80.1426E
>> Peace Research Institute Oslo (PRIO)
>> http://havard.security-review.net/
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110102/e92b7d6c/attachment-0001.html
