[gdal-dev] Re: PCIDSK .pix feature attribute information not visible in geomatica.
shashishaw shashishaw at gmail.com
Tue Jan 4 02:26:34 EST 2011
Apologies for the delay in replying and thanks for the response.
 @Frank: I did try to open the "ogr_polygon.pix" in geomatica. The different
attribute fields are empty, when viewing in the attribute manager.
@Chaitanya: Yes I did try using the ogr2ogr Utility. For the sake of test, I
used the utility to convert a .shp file to .pix and back to .shp. During the
transformation, the attribute information is lost.
Thanks,
Shashi.
On Tue, Jan 4, 2011 at 9:57 AM, Chaitanya kumar CH [via OSGeo.org] <
ml-node+5887620-911473961-309993 at n2.nabble.com<ml-node%2B5887620-911473961-309993 at n2.nabble.com>
> wrote:
> Shashi,
> Did you try the ogr2ogr utility?
>  On Mon, Jan 3, 2011 at 8:22 PM, shashishaw <[hidden email]<http://user/SendEmail.jtp?type=node&node=5887620&i=0>
> > wrote:
>> Hi,
>> I'm still not able to get past this problem. Can someone suggest any
>> pointers as to which aspect of the conversion should I look into.. Any
>> help
>> is appreciated.
>> Thanks,
>> Shashi
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/PCIDSK-pix-feature-attribute-information-not-visible-in-geomatica-tp5871388p5880861.html<http://osgeo-org.1803224.n2.nabble.com/PCIDSK-pix-feature-attribute-information-not-visible-in-geomatica-tp5871388p5880861.html?by-user=t>
>>   Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5887620&i=1>
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5887620&i=2>
> View message @
> http://osgeo-org.1803224.n2.nabble.com/PCIDSK-pix-feature-attribute-information-not-visible-in-geomatica-tp5871388p5887620.html
> To unsubscribe from PCIDSK .pix feature attribute information not visible
> in geomatica., click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5871388&code=c2hhc2hpc2hhd0BnbWFpbC5jb218NTg3MTM4OHwtMjAxODE2NTU3Ng==>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/PCIDSK-pix-feature-attribute-information-not-visible-in-geomatica-tp5871388p5887836.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110103/3542a180/attachment-0001.html
