Fwd: Re: [gdal-dev] FWTools and GDAL 1.7.0
Ari Jolma ari.jolma at gmail.com
Thu Jan 6 05:15:30 EST 2011
On 01/06/2011 01:18 AM, Tamas Szekeres wrote:
> Chris,
> Good points below, but having the compiled gdal binaries (and the
> binaries of the dependent libraries) in hand, which is the right way
> to install those files on Windows? (Assuming we don't provide
> python.exe and the related files in the package)? I mean which install
> actions should be done in detail?
> 2011/1/5 Christopher Barker:
>     Windows binaries built in MinGW are available at:
>     http://map.hut.fi/files/Geoinformatica/win32/
>     The Geoinformatica-yy-mm-dd.zip contains GDAL (usually a
>     development version), Perl-GDAL, Perl, and many other things.
>     good for MinGW users, I suppose -- I remember them not working for
>     me, tough I can't recall how or why not. They also suffer from
>     perhaps trying to be too much (though if it all worked, I wouldn't
>     care, I have a fast network and large hard drive)
I found it impossible to deliver a Windows binary solution, which would
depend on the three main packages (Perl, GTK+, and GDAL) to be retrieved
as binaries from some standard location - that's why I bundle them all
together into a quite large (32MB) package.
When I started there was only ActivePerl for Windows that was usable,
but it turned out impossible for me to use because they use MS
compilers. Now there is Strawberry Perl, which I might try again (or pay
someone to try). It is good because it uses MinGW.
There are binary installers for GTK+ for Windows, which install them
into a shared location - but there are problems still and some pieces
are missing that I need (Glade for example). The official GTK+ site has
a long list of zips containing binaries. Despite the shared nature of
GTK+, many projects include own binaries of them in Windows due to
version mismatches etc.
GDAL is available but again typically as MS compiler builds - which
should not be a problem in theory because the bindings use it through
the C API. I've tried to use those a couple of times without luck
(compiling the bindings in MinGW was the problem). Maybe I should try
again using binaries from Tamas' site.
I agree that there could be a one main site for GDAL Windows binaries
(something like http://www.gtk.org/download-windows.html). Tamas' site
looks good but I'd like to have dev packages also (the SDK packages
there look old) - just the header files should be enough.
Then there could also be a more end-user type Windows installation
package project for GDAL, which installs the stuff into some standard
location (c:\Program Files\share?). For GTK+ that's provided by some
folks at http://sourceforge.net/projects/gtk-win/
It would be neat to be able to just put to the Geoinformatica Windows
installer subinstallations, which go and get Perl, GTK+ and GDAL for the
user if she does not yet have them or has too old ones. In fact
Geoinformatica should be simply installable through Perl's cpan
application - but that does not even work in Linux yet :( (the reason is
that the GDAL Perl module installation script is not intelligent enough
and the version of the module in CPAN is horribly old and I really suck
at managing that)
Best regards,
Ari
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110106/b393bbdd/attachment.html
