[gdal-dev] ogr shapefile viewer
Mateusz Loskot mateusz at loskot.net
Thu Jan 6 12:07:06 EST 2011
On 06/01/11 16:58, Mohammed Rashad wrote:
> i checked it. Its not working properly and uses openGL
You didn't mention it can not be based on OpenGL or any other rendering
API. No idea what you mean "not working properly",
The code provides good example on how to read vectors from Shapefile
and pass to renderer. Just translate it to your renderer, Windows GDI,
GTK+, whatever.
If you want to use OGR, but not Shapelib, learn from OGR tutorial and do
the same thing.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
