[gdal-dev] FWTools and GDAL 1.7.0
Jürgen E. Fischer jef at norbit.de
Thu Jan 6 18:56:58 EST 2011
Hi Frank,
On Thu, 06. Jan 2011 at 17:00:31 -0500, Frank Warmerdam wrote:
> I have no objection to using \Program Files\GDAL\<major>.<minor>\ as a
> standard location for GDAL stuff on windows.  If this is done, the GDAL
> data search location should be compiled in for this location on windows,
> much as it defaults to /usr/share/gdal (or /usr/local/share/gdal) on
> linux.
Just one remark (I don't follow all the python stuff ;)):
The program files directory is usually localized so %PROGRAMFILES% should be
used and the drive letter isn't necessarily C.
Windows 7 might actually be different - perhaps they now even now use symlinks
to point a localized path to a hidden "Program Files".
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
