Fwd: Re: [gdal-dev] FWTools and GDAL 1.7.0
Chris Barker Chris.Barker at noaa.gov
Sat Jan 8 12:05:23 EST 2011
On 1/6/2011 4:25 PM, Joaquim Luis wrote:
>> By the way, isn't there some new stuff about "side by side" installs
>> or something -- that's supposed to help dll hell?
> I think you are referring to the "manifests" but here also MS has
> changed their mind (aleluia). VC2010 doesn't have them anymore which IMO
> is a compelling reason to use this compiler whenever possible.
This is what I was talking about:
http://msdn.microsoft.com/en-us/library/aa376307%28VS.85%29.aspx
It does look like it is (or was) MS's solution to dll hell -- however, I
remember it causing much pain for wxPython (particularly for py2exe),
and I'm happy to defer to the experts here that seem to know that the
cure was worse than the disease.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
