[gdal-dev] GDAL windows installers available
Tamas Szekeres szekerest at gmail.com
Sun Jan 9 09:03:27 EST 2011
Michael,
You probably did a full install which is not recommended if the Oracle
environment is not in place. Try removing the OCI plugin by the add/remove
option.
Best regards,
Tamas
2011/1/9 Michael Sumner <mdsumner at gmail.com>
> Awesome, thanks for this - I've really enjoyed the discussion too, a
> great deal of good information there.
> I downloaded and ran
> http://vbkto.dyndns.org/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver\gdal-18dev-1600-x64-core.msi<http://vbkto.dyndns.org/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver%5Cgdal-18dev-1600-x64-core.msi>
> on Windows 7 64-bit. I removed an existing path reference to a build
> from your site, then started the installed "GDAL 18dev (MSVC 2010
> Win64) Command Prompt" shortcut. On running "gdalinfo" I get two
> repeated popup errors:
> gdalinfo.exe - System Error
> The program can't start because OCI.dll is missing from your computer.
> Try reinstalling the program to fix this problem.
> OK
> and this in the command window:
> C:\Program Files\GDAL>gdalinfo
> ERROR 1: Can't load requested DLL: C:\Program
> Files\GDAL\gdalplugins\gdal_GEOR.dll
> 126: The specified module could not be found.
> Usage: gdalinfo [--help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
>                [-norat] [-noct] [-checksum] [-mdd domain]* datasetname
> Otherwise it reports fine on a basic GeoTIFF.
> Thanks again, and I hope that small detail is of some use.
> Cheers, Mike.
> On Sun, Jan 9, 2011 at 11:51 PM, Tamas Szekeres <szekerest at gmail.com>
> wrote:
> > Folks,
> > Upon the inspiration on the recent conversation in this topic I've put
> some
> > efforts to automate the creation of a generic GDAL installer derived from
> > the distributions available at http://vbkto.dyndns.org/sdk/.
> > Currently the following options are available from this site to install
> and
> > use GDAL:
> > 1. Download the .zip package extract it in some location and run
> > SDKShell.bat to run the commandline tools (this is the former approach)
> > 2. Use the core msi installer to install GDAL and use the installed
> shortcut
> > to run the command line tools.  Python users should install the python
> > bindings installer as well.
> > In order to have the bindings work the location of the core files should
> be
> > added to the PATH manually (this requirement will probably be removed in
> the
> > future when the automatic loader approach is implemented at the bindings)
> > The core installer places an entry in the registry (currently in HKCU)
> > containing the install location which will allow the loader to find the
> > required components.
> > This task is not yet complete, the following issues are to be handled or
> > reviewed in some way.
> > 1. Side by side installation of the multiple versions is not yet
> supported.
> > 2. Must review the license agreement (currently taken from the GDAL site)
> > 3. Must review the product name
> > 4. Must review the installer design
> > 5. Must review the selectable features
> > 6. Loader approach to be implemented for the bindings
> > 7. Versioning rules should be clarified (should synchronize the registry
> > entries among the versions)
> > 8. Further fixes
> > The core installer is provided as a single wix project file the build
> > process is executed by the command line apps (candle.exe and light.exe).
> I
> > will make the whole approach public as part to the -dev packages at
> > http://vbkto.dyndns.org/sdk/. By using this addition one can easily
> rebuild
> > the installer after creating a customized GDAL build.
> > The wix project file could also be included in GDAL source tree and a new
> > target could be added in the gdal makefile for creating the installer
> (the
> > CRT redistributable merge modules and the dependent dlls must be
> available
> > during the build). Having the locations of the OSGeo4w files in place,
> this
> > approach could easily generate the same installer for the OSGeo4w bundle.
> > Any testing efforts / comments / wishes are graciously accepted.
> > Best regards,
> > Tamas
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Michael Sumner
> Institute for Marine and Antarctic Studies, University of Tasmania
> Hobart, Australia
> e-mail: mdsumner at gmail.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110109/864710bf/attachment-0001.html
