[gdal-dev] GDAL windows installers available
Michael Sumner mdsumner at gmail.com
Mon Jan 10 05:43:33 EST 2011
Ah, yes - a Typical mistake on my part. All good, thanks a lot!
Cheers, Mike.
On Mon, Jan 10, 2011 at 1:03 AM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Michael,
> You probably did a full install which is not recommended if the Oracle
> environment is not in place. Try removing the OCI plugin by the add/remove
> option.
> Best regards,
> Tamas
> 2011/1/9 Michael Sumner <mdsumner at gmail.com>
>> Awesome, thanks for this - I've really enjoyed the discussion too, a
>> great deal of good information there.
>> I downloaded and ran
>> http://vbkto.dyndns.org/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver\gdal-18dev-1600-x64-core.msi
>> on Windows 7 64-bit. I removed an existing path reference to a build
>> from your site, then started the installed "GDAL 18dev (MSVC 2010
>> Win64) Command Prompt" shortcut. On running "gdalinfo" I get two
>> repeated popup errors:
>> gdalinfo.exe - System Error
>> The program can't start because OCI.dll is missing from your computer.
>> Try reinstalling the program to fix this problem.
>> OK
>> and this in the command window:
>> C:\Program Files\GDAL>gdalinfo
>> ERROR 1: Can't load requested DLL: C:\Program
>> Files\GDAL\gdalplugins\gdal_GEOR.dll
>> 126: The specified module could not be found.
>> Usage: gdalinfo [--help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
>>                [-norat] [-noct] [-checksum] [-mdd domain]* datasetname
>> Otherwise it reports fine on a basic GeoTIFF.
>> Thanks again, and I hope that small detail is of some use.
>> Cheers, Mike.
>> On Sun, Jan 9, 2011 at 11:51 PM, Tamas Szekeres <szekerest at gmail.com>
>> wrote:
>> > Folks,
>> > Upon the inspiration on the recent conversation in this topic I've put
>> > some
>> > efforts to automate the creation of a generic GDAL installer derived
>> > from
>> > the distributions available at http://vbkto.dyndns.org/sdk/.
>> > Currently the following options are available from this site to install
>> > and
>> > use GDAL:
>> > 1. Download the .zip package extract it in some location and run
>> > SDKShell.bat to run the commandline tools (this is the former approach)
>> > 2. Use the core msi installer to install GDAL and use the installed
>> > shortcut
>> > to run the command line tools.  Python users should install the python
>> > bindings installer as well.
>> > In order to have the bindings work the location of the core files should
>> > be
>> > added to the PATH manually (this requirement will probably be removed in
>> > the
>> > future when the automatic loader approach is implemented at the
>> > bindings)
>> > The core installer places an entry in the registry (currently in HKCU)
>> > containing the install location which will allow the loader to find the
>> > required components.
>> > This task is not yet complete, the following issues are to be handled or
>> > reviewed in some way.
>> > 1. Side by side installation of the multiple versions is not yet
>> > supported.
>> > 2. Must review the license agreement (currently taken from the GDAL
>> > site)
>> > 3. Must review the product name
>> > 4. Must review the installer design
>> > 5. Must review the selectable features
>> > 6. Loader approach to be implemented for the bindings
>> > 7. Versioning rules should be clarified (should synchronize the registry
>> > entries among the versions)
>> > 8. Further fixes
>> > The core installer is provided as a single wix project file the build
>> > process is executed by the command line apps (candle.exe and light.exe).
>> > I
>> > will make the whole approach public as part to the -dev packages at
>> > http://vbkto.dyndns.org/sdk/. By using this addition one can easily
>> > rebuild
>> > the installer after creating a customized GDAL build.
>> > The wix project file could also be included in GDAL source tree and a
>> > new
>> > target could be added in the gdal makefile for creating the installer
>> > (the
>> > CRT redistributable merge modules and the dependent dlls must be
>> > available
>> > during the build). Having the locations of the OSGeo4w files in place,
>> > this
>> > approach could easily generate the same installer for the OSGeo4w
>> > bundle.
>> > Any testing efforts / comments / wishes are graciously accepted.
>> > Best regards,
>> > Tamas
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Michael Sumner
>> Institute for Marine and Antarctic Studies, University of Tasmania
>> Hobart, Australia
>> e-mail: mdsumner at gmail.com
Michael Sumner
Hobart, Australia
