[gdal-dev] Hierarchical Data Format-EOS 2 conversion in Gdal
Nikolaos Hatzopoulos nhatzop at gmail.com
Tue Jan 11 23:07:21 EST 2011
for me it's working
gdalinfo GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf
Driver: HDF4/Hierarchical Data Format Release 4
Files: GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf
Size is 512, 512
Coordinate System is `'
Metadata:
  HDFEOSVersion=HDFEOS_V2.12
Subdatasets:
SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_1
  SUBDATASET_1_DESC=[1800x1800] MEAN_1 POSTEL (16-bit integer)
SUBDATASET_2_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_2
  SUBDATASET_2_DESC=[1800x1800] MEAN_2 POSTEL (16-bit integer)
SUBDATASET_3_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_3
  SUBDATASET_3_DESC=[1800x1800] MEAN_3 POSTEL (16-bit integer)
SUBDATASET_4_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_4
  SUBDATASET_4_DESC=[1800x1800] MEAN_4 POSTEL (16-bit integer)
SUBDATASET_5_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_5
  SUBDATASET_5_DESC=[1800x1800] MEAN_5 POSTEL (16-bit integer)
SUBDATASET_6_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_6
  SUBDATASET_6_DESC=[1800x1800] MEAN_6 POSTEL (16-bit integer)
SUBDATASET_7_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_7
  SUBDATASET_7_DESC=[1800x1800] MEAN_7 POSTEL (16-bit integer)
SUBDATASET_8_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_8
  SUBDATASET_8_DESC=[1800x1800] MEAN_8 POSTEL (16-bit integer)
SUBDATASET_9_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_9
  SUBDATASET_9_DESC=[1800x1800] MEAN_9 POSTEL (16-bit integer)
SUBDATASET_10_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_10
  SUBDATASET_10_DESC=[1800x1800] MEAN_10 POSTEL (16-bit integer)
SUBDATASET_11_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_12
  SUBDATASET_11_DESC=[1800x1800] MEAN_12 POSTEL (16-bit integer)
SUBDATASET_12_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_13
  SUBDATASET_12_DESC=[1800x1800] MEAN_13 POSTEL (16-bit integer)
SUBDATASET_13_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:MEAN_14
  SUBDATASET_13_DESC=[1800x1800] MEAN_14 POSTEL (16-bit integer)
SUBDATASET_14_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:NMOD
  SUBDATASET_14_DESC=[1800x1800] NMOD POSTEL (8-bit unsigned integer)
SUBDATASET_15_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:SM
  SUBDATASET_15_DESC=[1800x1800] SM POSTEL (16-bit unsigned integer)
SUBDATASET_16_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_1
  SUBDATASET_16_DESC=[1800x1800] ERR_1 POSTEL (8-bit unsigned integer)
SUBDATASET_17_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_2
  SUBDATASET_17_DESC=[1800x1800] ERR_2 POSTEL (8-bit unsigned integer)
SUBDATASET_18_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_3
  SUBDATASET_18_DESC=[1800x1800] ERR_3 POSTEL (8-bit unsigned integer)
SUBDATASET_19_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_4
  SUBDATASET_19_DESC=[1800x1800] ERR_4 POSTEL (8-bit unsigned integer)
SUBDATASET_20_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_5
  SUBDATASET_20_DESC=[1800x1800] ERR_5 POSTEL (8-bit unsigned integer)
SUBDATASET_21_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_6
  SUBDATASET_21_DESC=[1800x1800] ERR_6 POSTEL (8-bit unsigned integer)
SUBDATASET_22_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_7
  SUBDATASET_22_DESC=[1800x1800] ERR_7 POSTEL (8-bit unsigned integer)
SUBDATASET_23_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_8
  SUBDATASET_23_DESC=[1800x1800] ERR_8 POSTEL (8-bit unsigned integer)
SUBDATASET_24_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_9
  SUBDATASET_24_DESC=[1800x1800] ERR_9 POSTEL (8-bit unsigned integer)
SUBDATASET_25_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_10
  SUBDATASET_25_DESC=[1800x1800] ERR_10 POSTEL (8-bit unsigned integer)
SUBDATASET_26_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_12
  SUBDATASET_26_DESC=[1800x1800] ERR_12 POSTEL (8-bit unsigned integer)
SUBDATASET_27_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_13
  SUBDATASET_27_DESC=[1800x1800] ERR_13 POSTEL (8-bit unsigned integer)
SUBDATASET_28_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:ERR_14
  SUBDATASET_28_DESC=[1800x1800] ERR_14 POSTEL (8-bit unsigned integer)
SUBDATASET_29_NAME=HDF4_EOS:EOS_GRID:"GLOBCOVER-L3_MOSAIC_2005_V2.0_ANNUAL_H35V15.hdf":POSTEL:NDVI
  SUBDATASET_29_DESC=[1800x1800] NDVI POSTEL (8-bit unsigned integer)
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  512.0)
Upper Right (  512.0,    0.0)
Lower Right (  512.0,  512.0)
Center      (  256.0,  256.0)
something is going wrong with your hdf library or it's not linked well
or the compilation is not correct of gdal
I will repeat again I am using elgis for centos linux I don't know what's
going on
on Ubuntu
On Tue, Jan 11, 2011 at 8:04 AM, Nikolaos Hatzopoulos <nhatzop at gmail.com>wrote:
> is there any sample of these data online?
> On Tue, Jan 11, 2011 at 6:00 AM, abausch <adam.bausch at gmail.com> wrote:
>>  Hi Nikolaos,
>> I wish I were using the level 2 product in .N1 format but the level 3
>> MERIS mosaics are processed to .hdf - EOS2.  I can work with N1 data just
>> fine if that were the case, but batch processing with BEAM doesn't support
>> what I am trying to do with HDF's (unless I could program in Java..yikes)
>> Best,
>> Adam
>> On 1/10/11 10:54 PM, Nikolaos Hatzopoulos wrote:
>> from here:
>> http://www.brockmann-consult.de/cms/web/beam/meris-products
>> I download this file which is level2 data:
>> http://www.brockmann-consult.de/beam/data/products/MER_FR__2PNEPA20030714_102918_000000982018_00094_07162_0053.zip
>> gdalinfo gives me:
>> Driver: ESAT/Envisat Image Format
>> Files: MER_FR__2PNEPA20030714_102918_000000982018_00094_07162_0053.N1
>> Size is 2241, 2241
>> GCP Projection =
>> GEOGCS["WGS 84",
>>     DATUM["WGS_1984",
>>         SPHEROID["WGS 84",6378137,298.257223563,
>>             AUTHORITY["EPSG","7030"]],
>>         TOWGS84[0,0,0,0,0,0,0],
>>         AUTHORITY["EPSG","6326"]],
>>     PRIMEM["Greenwich",0,
>>         AUTHORITY["EPSG","8901"]],
>>     UNIT["degree",0.0174532925199433,
>>         AUTHORITY["EPSG","9108"]],
>>     AUTHORITY["EPSG","4326"]]
>> GCP[  0]: Id=1, Info=
>>           (0.5,0.5) -> (10.599538,56.49672,0)
>> Metadata:
>> MPH_PRODUCT=MER_FR__2PNEPA20030714_102918_000000982018_00094_07162_0053.N1
>>   MPH_PROC_STAGE=N
>>   MPH_REF_DOC=PO-RS-MDA-GS2009_11_3J
>>   MPH_ACQUISITION_STATION=PDHS-K
>>   MPH_PROC_CENTER=E-PAC
>>   MPH_PROC_TIME=04-AUG-2003 15:12:31.508420
>>   MPH_SOFTWARE_VER=MERIS/4.06
>>   MPH_SENSING_START=14-JUL-2003 10:26:32.276537
>>   MPH_SENSING_STOP=14-JUL-2003 10:32:37.452300
>>   MPH_PHASE=2
>>   MPH_CYCLE=+018
>>   MPH_REL_ORBIT=+00094
>>   MPH_ABS_ORBIT=+07162
>>   MPH_STATE_VECTOR_TIME=14-JUL-2003 10:27:00.000000
>>   MPH_DELTA_UT1=-.359896
>>   MPH_X_POSITION=+2948879.180
>>   MPH_Y_POSITION=+0636697.527
>>   MPH_Z_POSITION=+6488093.331
>>   MPH_X_VELOCITY=+6793.676563
>>   MPH_Y_VELOCITY=-1452.749368
>>   MPH_Z_VELOCITY=-2938.824735
>>   MPH_VECTOR_SOURCE=FR
>>   MPH_UTC_SBT_TIME=14-JUL-2003 10:18:36.710154
>>   MPH_SAT_BINARY_TIME=+2483253760
>>   MPH_CLOCK_STEP=+3906249805
>>   MPH_LEAP_UTC=17-OCT-2001 00:00:00.000000
>>   MPH_LEAP_SIGN=+001
>>   MPH_LEAP_ERR=0
>>   MPH_PRODUCT_ERR=1
>>   SPH_SPH_DESCRIPTOR=MER_FR__2P SPECIFIC HEADER
>>   SPH_STRIPLINE_CONTINUITY_INDICATOR=+000
>>   SPH_SLICE_POSITION=+001
>>   SPH_NUM_SLICES=+001
>>   SPH_FIRST_LINE_TIME=14-JUL-2003 10:29:18.385327
>>   SPH_LAST_LINE_TIME=14-JUL-2003 10:30:56.938607
>>   SPH_FIRST_FIRST_LAT=+0056496720
>>   SPH_FIRST_FIRST_LONG=+0010599537
>>   SPH_FIRST_MID_LAT=+0057382170
>>   SPH_FIRST_MID_LONG=+0006097018
>>   SPH_FIRST_LAST_LAT=+0058099238
>>   SPH_FIRST_LAST_LONG=+0001394104
>>   SPH_LAST_FIRST_LAT=+0050903410
>>   SPH_LAST_FIRST_LONG=+0007084803
>>   SPH_LAST_MID_LAT=+0051698757
>>   SPH_LAST_MID_LONG=+0003106173
>>   SPH_LAST_LAST_LAT=+0052354870
>>   SPH_LAST_LAST_LONG=-0001001598
>>   SPH_TRANS_ERR_FLAG=0
>>   SPH_FORMAT_ERR_FLAG=0
>>   SPH_DATABASE_FLAG=0
>>   SPH_COARSE_ERR_FLAG=1
>>   SPH_ECMWF_TYPE=1
>>   SPH_NUM_TRANS_ERR=+0000000000
>>   SPH_NUM_FORMAT_ERR=+0000000000
>>   SPH_TRANS_ERR_THRESH=+0.00000000E+00
>>   SPH_FORMAT_ERR_THRESH=+0.00000000E+00
>>   SPH_NUM_BANDS=+015
>> SPH_BAND_WAVELEN=+0000412545+0000442401+0000489744+0000509700+0000559634+00006
>> 19620+0000664640+0000680902+0000708426+0000753472+0000761606+0000778498+00008648
>> 33+0000884849+0000899860
>> SPH_BANDWIDTH=+09930+09946+09965+09971+09983+09991+09994+07493+09996+07493+037
>> 42+15000+19999+09990+09989
>>   SPH_INST_FOV=+0000019159
>>   SPH_PROC_MODE=1
>>   SPH_OFFSET_COMP=1
>>   SPH_LINE_TIME_INTERVAL=+0000043997
>>   SPH_LINE_LENGTH=+02241
>>   SPH_LINES_PER_TIE_PT=+064
>>   SPH_SAMPLES_PER_TIE_PT=+064
>>   SPH_COLUMN_SPACING=+2.60000000E+02
>> DS_LEVEL_1B_PRODUCT_NAME=MER_FR__1PNEPA20030714_102918_000000982018_00094_0716
>> 2_0120.N1
>> DS_AEROSOL_CLIMATOLOGY_FILE_NAME=MER_AER_AXVIEC20030620_120000_20020321_193100
>> _20200101_000000
>> DS_PROCESSING_PARAMS_L2_FILE_NAME=MER_CP2_AXVIEC20030620_120000_20021224_12144
>> 5_20121224_121445
>> DS_ATMOSPHERIC_PARAMETERS_FILE_NAME=MER_ATP_AXVIEC20030620_120000_20021224_121
>> 445_20121224_121445
>> DS_WATER_VAPOUR_PARAMETERS_FILE_NAME=MER_WVP_AXVIEC20030620_120000_20020321_19
>> 3100_20120321_193100
>> DS_OCEAN_AEROSOLS_PARAMS_FILE_NAME=MER_OAP_AXVIEC20030620_120001_20020321_1931
>> 00_20120321_193100
>> DS_LAND_AEROSOLS_PARAMS_FILE_NAME=MER_LAP_AXVIEC20030715_151450_20020321_19310
>> 0_20120321_193100
>> DS_OCEAN_I_PARAMETERS_FILE_NAME=MER_OC1_AXVIEC20030620_120000_20020321_193100_
>> 20120321_193100
>> DS_OCEAN_II_PARAMETERS_FILE_NAME=MER_OC2_AXVIEC20030620_120000_20020321_193100
>> _20120624_174339
>> DS_CLOUD_MEASUREMENT_FILE_NAME=MER_CMP_AXVIEC20030620_120000_20021224_121445_2
>> 0120321_193100
>> DS_LAND_VEGETATION_INDEX_FILE_NAME=MER_LVI_AXVIEC20030620_120000_20020321_1931
>> 00_20130224_164916
>> Corner Coordinates:
>> Lower Left  (    0.0, 2241.0)
>> Upper Right ( 2241.0,    0.0)
>> Lower Right ( 2241.0, 2241.0)
>> Center      ( 1120.5, 1120.5)
>> Band 1 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(1)
>> Band 2 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(2)
>> Band 3 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(3)
>> Band 4 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(4)
>> Band 5 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(5)
>> Band 6 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(6)
>> Band 7 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(7)
>> Band 8 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(8)
>> Band 9 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(9)
>> Band 10 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(10)
>> Band 11 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(11)
>> Band 12 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(12)
>> Band 13 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Norm. rho_surf - MDS(13)
>> Band 14 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = YS, SPM, Rect. Rho- MDS(16)
>> Band 15 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>>   Description = Epsilon, OPT   - MDS(19)
>> I am using centos linux
>> On Mon, Jan 10, 2011 at 12:54 PM, Adam Bausch <abausch at nova.whrc.org>wrote:
>>>  Hi,
>>> I get the following error.
>>> GDALOpen failed - 4
>>> `H29V13.hdf' not recognised as a supported file format.
>>> Thanks for the link.
>>>  Adam
>>> On 1/10/11 3:31 PM, Nikolaos Hatzopoulos wrote:
>>> what gdalinfo gives you?
>>> this is a very helpful link http://www.gdal.org/frmt_hdf4.html
>>> On Mon, Jan 10, 2011 at 10:19 AM, Adam Bausch <abausch at nova.whrc.org>wrote:
>>>> Hi All,
>>>> I am attempting to process a large volume of MERIS mosaic data obtained
>>>> from ENVISAT in HDF-EOS2 format, however, I continue to get a "not a
>>>> supported format" error when I try to run it.  I have installed the HDF-4
>>>> (libdf), HDF-5 (libhdf5) and NetCDF libraries and checked with our
>>>> Linux/Unix administrator to try and identify the problem with no resolution.
>>>>  I was wondering if anyone else has had this problem or if there is a fix.
>>>> Best,
>>>> Adam
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110111/c1be5226/attachment-0001.html
