[gdal-dev] Problems with passing parameters into gdalwrap in Python
manzione james.j.manzione at usace.army.mil
Wed Jan 12 16:36:15 EST 2011
Greetings All,
I am a student who has been having a difficult time passing in source
parameters into gdalwrap in Python, and would truly appreciate any insight
that great minds like you might have on my simple problem.
First off, I am attempting to reproject a Tiff image that was generated from
a Grib2 rasterband by using the subprocess.call(cmd) method.  My cmd
statement is as follows:
cmd = ["gdalwarp", "-t_srs", "EPSG:4326", in_Src, target_Src]
The "in_Src" parameter represents the input source file, and the
"target_Src" parameter is an empty temporary file.
I've seen (and tried) a lot of examples where instead of calling an object
in the cmd line they call a string that references the name of the image
file.
Example:  subprocess.call(["gdalwarp", "-t_srs", "EPSG:4326", "input.tif",
"output.tif"])
However each time I attempt this technique gdalwarp returns an error message
that states that it cannot locate the source file.  I've tried replacing the
names with path locations and yet I still get the same error returned.
If someone would be kind enough to show me how to get over this issue I
would be incredibly grateful!
Thank you in advance,
-James
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-passing-parameters-into-gdalwrap-in-Python-tp5916192p5916192.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
