[gdal-dev] GDAL/OGR 1.8.0RC2 Release Candidate Prepared
William Kyngesburye woklist at kyngchaos.com
Sat Jan 15 17:17:25 EST 2011
Oh, right after sending I poked around in the alg/ source folder.  And remembered enabling OpenCL.  After disabling OpenCL, the warp errors returned to normal (a few minor diffs).
On Jan 15, 2011, at 3:51 PM, William Kyngesburye wrote:
> Looks mostly good here.
> I submitted a couple build bugs (1 fixed already) and autotest bugs.
> I'm having problems in the warp tests.  Diffs are a lot greater than from GDAL 1.7, including a few failures.  I don't know if it's just something different on my system from when I last compiled GDAL 1.7 or if there were some big changes in the code.  Any ideas before I submit a bug report on this?
> On Jan 13, 2011, at 11:33 PM, Frank Warmerdam wrote:
>> Folks,
>> Some problems were discovered with the Python bindings in the RC
>> being out of date, and the generated perl bindings being complete
>> missing.  I have prepared a new release candidate for GDAL/OGR 1.8.0.
>> The source, testsuite and documentation can be found at:
>> http://download.osgeo.org/gdal/gdal-1.8.0RC2.tar.gz
>> http://download.osgeo.org/gdal/gdal180RC2.zip
>> http://download.osgeo.org/gdal/gdal180doc.zip
>> http://download.osgeo.org/gdal/gdalautotest-1.8.0.tar.gz
>> I would appreciate broad testing of the release candidate and reporting
>> problems via Trac tickets:
>> http://trac.osgeo.org/gdal/
>> If things seem respectable I will introduce a motion to promote this
>> release candidate as a final 1.8.0 release in the next day or two.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Programmer for Rent
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
> - the wisdom of Tarzan
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
