[gdal-dev] Create a shape file with polygons
Tue Jan 18 12:10:59 EST 2011
On 11-01-18 11:28 AM, Jorge Martin wrote:
> OGRPolygon myPoligon;
> tmp = strtok (Line, ":");
> szName = string (tmp);
>         while (tmp != NULL)
>         OGRLinearRing MyRing;// = (OGRLinearRing*)
> OGRGeometryFactory::createGeometry(wkbLinearRing);
>          tmp = strtok (NULL, ",");
>          if(tmp)
>                 string Coords = string(tmp);
>                size_t pos = Coords.find(" ");
>                string CoordX = Coords.substr(0,pos);
>                string CoordY = Coords.substr(pos);
>                x = atof(CoordX.c_str());
>                 y = atof(CoordY.c_str());
> MyRing.addPoint(x,y);
>          myPoligon.addRing(&MyRing);
Jorge,
The essence of your problem is that you are creating a new
ring for each point instead of creating one ring for the
polygon and adding all the points to that ring before adding
the ring to the polygon.  A slightly altered form of the core
that works looks like:
         while (tmp != NULL)
             if(tmp)
Best regards,
