[gdal-dev] create attribute table
Fri Jan 21 10:01:53 EST 2011
On 11-01-21 09:49 AM, Mohammed Rashad wrote:
> how to create attribute table for vector using ogr?
Mohammed,
New attribute fields are created on a vector layer in OGR using the
CreateField() method on the layer.  This is covered in the read/write
tutorial (search for CreateField about 2/3 of the way down):
   http://www.gdal.org/ogr/ogr_apitut.html
See also:
   http://www.gdal.org/ogr/classOGRLayer.html#00b1376a1eabb1298ef278f92f6d84be
Best regards,
