[gdal-dev] segfault on importFromWkt
Fri Jan 21 13:11:24 EST 2011
On 11-01-21 12:47 PM, Mohammed Rashad wrote:
>          OGRGeometry *OLGeometry;
>   char *geom = "POINT(6 10)";
>          OLGeometry->importFromWkt(&geom);
Rashad,
The problem is that OLGeometry is an unitialized pointer as opposed to
being a valid geometry object on which a method could be invoked.
I would suggest changing this to:
   OGRGeometry *OLGeometry = NULL;
   OGRGeometryFactory::createFromWkt( &geom, NULL, &OLGeometry );
Note that the documentation on OGRGeometry::importFromWkt() says:
  * The object must have already been instantiated as the correct derived
  * type of geometry object to match the text type.  This method is used
  * by the OGRGeometryFactory class, but not normally called by application
  * code.
Best regards,
