[gdal-dev] HDF4 file in byte array results in "not recognised" error
Sam Ritchie sritchie09 at gmail.com
Mon Jan 24 15:59:35 EST 2011
Even, thanks for this. I'll proceed by copying the byte array to a temp
file.
Best,
Sam
On Mon, Jan 24, 2011 at 3:54 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Sam,
> not all drivers support the vsi virtual file systems, such as /vsimem. And
> HDF4
> is one of those drivers (the HDF4 libs need a "real" filename). You can
> generally check if a file system supports vsi virtual file systems by
> issuing
> "gdalinfo --format name_of_driver"
> For a compatible driver (such as VRT, but not HDF4), you'll see :
>  Supports: Virtual IO - eg. /vsimem/
> > Hey all,
> > I'm working on an app that needs to pass HDF4 files (MODIS tiles) around
> as
> > byte arrays, and then open them up using gdal#Open, from java. Open works
> > great when I pass in the filepath, so I know that my gdal setup is solid.
> > The problem is, when I turn the HDF4 file into a byte array and try to
> use
> > gdal.FileFromMemBuffer("/vsimem/test.hdf", bytearray);
> > DataSet data = gdal.Open("/vsimem/test.hdf");
> > I get an error that reads: "`/vsimem/test.hdf' not recognised as a
> > supported file format."
> > I tried something similar, by converting
> > <VRTDataset rasterXSize=\"1\" rasterYSize=\"1\">
> >   <GeoTransform>100,1,0,100,0,-1</GeoTransform>
> >   <VRTRasterBand dataType=\"Byte\" band=\"1\">
> >   </VRTRasterBand>
> > </VRTDataset>
> > to a byte array and reading it in, and that worked great.
> > Any ideas on how to deal with this issue? I'll note that open SEES the
> file
> > in the /vsimem/ directory, it just doesn't recognize it as a valid file.
> Is
> > this an issue with HDF4 files, or with large binary sequences? Any ideas
> on
> > how to get around this?
> > Thanks, all,
> > Sam
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110124/882ec95f/attachment.html
