Re: [gdal-dev] Problem with GDAL Python bindings and ECW format under Windows
Ivan Lucena ivan.lucena at pmldnet.com
Tue Jan 25 10:56:56 EST 2011
Alain,
Do you have the GDAL_DRIVER_PATH environment variable set on your Windows system?
C:\>echo %GDAL_DRIVER_PATH%
C:\Apps\GDAL\bin\gdalplugins
That is what going to make the GDAL dll inside the Python process to find the plugins. GDAL command line tools doesn't need that because they get it from a default path relative to where they are installed ".\gdalplugins".
Regards,
Ivan
>  -------Original Message-------
>  From: Alain Cembro <acembro at yahoo.com>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] Problem with GDAL Python bindings and ECW format under Windows
>  Sent: Jan 25 '11 10:25
>  Hello list,
>  I have written a Python program to create ECW files. It is working fine under Linux, but not under Windows XP.
>  I have installed :
>  - Python 2.6.6 (the official version)
>  - gdal-18-1500-core.msi
>  - gdal-18-1500-ecw.msi
>  - GDAL-1.8.0.win32-py2.6.exe
>  I downloaded the last three files at http://vbkto.dyndns.org/sdk/
>  GDAL is working :
>  - gdalinfo lists the ECW format as available (rw).
>  - I can create ECW files with gdal_translate.
>  But in a Python console, osgeo.gdal.getDriverByName("ECW") return None.
>  Is it a known problem, or is there something wrong in my installation ?
>  Thanks for any help.
>  _______________________________________________
>  gdal-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
