[gdal-dev] Problem with GDAL Python bindings and ECW format under Windows
Alain Cembro acembro at yahoo.com
Tue Jan 25 11:31:11 EST 2011
--- On Tue, 1/25/11, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
> Do you have the GDAL_DRIVER_PATH environment variable set
> on your Windows system?
> C:\>echo %GDAL_DRIVER_PATH%
> C:\Apps\GDAL\bin\gdalplugins
Ivan,
You are right, I forgot to set that variable. Now it is working. Thank you very much !
Tamas,
Could you improve the Windows GDAL installer, so that it automatically sets the environment variables (GDAL_DATA and GDAL_DRIVER_PATH), and adds the GDAL binaries path to the PATH environment variable ?
Thanks !
