[gdal-dev] projection in external file
morabit b.morabito at tdnet.it
Wed Jan 26 08:33:16 EST 2011
Hi All,
 In our project we have to support the loading of tiff images
that will be geo-referenced by means of external companion
files containing the affine geo transformation and projection
information (WKT).
We have tested that GDAL supports external geo-transform
using .tfw files, but we are not able to load WKT info included
in companion .proj or .wkt files.
Does GDAL support this kind of feature?
Perhaps it supports this feature using some other format (aux.xml)?
In case of positive answer, what is the right way to accomplish this?
Thank you for your attention
Bruno
View this message in context: http://osgeo-org.1803224.n2.nabble.com/projection-in-external-file-tp5962689p5962689.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
