[gdal-dev] GDAL 1.8 - Switch Thrown
Fri Jan 28 21:59:57 EST 2011
Folks,
I have had good success with the GDAL 1.8 upgrade and I have now thrown
the switch migrating it into the production version of OSGeo4W.
I have upgraded "gdal", "gdal-python", "gdal-mrsid" and "gdal-autotest".
I have yet to upgrade the ecw, and sde related drivers, and I have not
upgraded the java bindings.  I will try to work on them tomorrow.
The gdal15dll package was created for backward compatability and should
be automatically pulled in.  It seems to be working fine for OpenEV.
I would encourage folks building packages to update, and rebuild them
using the current GDAL.  The GDAL include files in C:\OSGeo4W\include
and libraries in C:\OSGeo4w\lib should now be for 1.8.
Note that the new GDAL package is built using Visual Studio 2008
Express instead of 2003.  If you are using the C++ API this may cause
issues but if you use the C API it should be invisible.
Let me know of problems.
Best regards,
