[gdal-dev] Re: GDAL Error 1: TIFFFetchDirectory:Sanity check on directory count failed . . .
Neil Best nbest at ci.uchicago.edu
Sat Jan 29 09:53:30 EST 2011
Thanks, Even.  That makes sense.  If I understand your suggestion I can
create a trivial VRT pointing to the input data for each worker, correct?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-Error-1-TIFFFetchDirectory-Sanity-check-on-directory-count-failed-tp5972745p5972790.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
