[gdal-dev] GDAL 1.8 - Switch Thrown
Jürgen E. Fischer jef at norbit.de
Sat Jan 29 11:51:13 EST 2011
Hi Ari,
On Sat, 29. Jan 2011 at 16:52:46 +0200, Ari Jolma wrote:
> Did anybody else try to use the now standard Visual Studio built GDAL
> DLL (which was much discussed some time ago here and is now available
> from Tamas' site) in a MinGW environment?
The OSGeo4W GRASS package (and AFAIK also the standalone WinGRASS package) is
built with MinGW using the libraries for OSGeo4W (ie. with GDAL, GEOS and
PROJ.4 build with MSVC).   AFAIK that seems to work fine - although I must
admit to what extent GDAL/OGR is used in GRASS.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
