[gdal-dev] GDAL 1.8 - Switch Thrown
Jürgen E. Fischer jef at norbit.de
Sun Jan 30 17:41:02 EST 2011
Hi Ari,
On Sun, 30. Jan 2011 at 11:36:49 +0200, Ari Jolma wrote:
>    to the .def file. I create the .dll.a, which is the import library, with
>    dlltool from the .def.
Did you try to link the gdal_c_i.lib instead of generating your own library
from the DLL?  That what I do with GRASS.  Works fine for me - just the reverse
doesn't.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
